Activity Forums DaVinci Resolve Always stop at 99% of render queue.
  • Always stop at 99% of render queue.
    Posted by Nick Anderson on September 16, 2011 at 7:41 pm
    Whenever I wanted to use the render queue, it always freeze at the last frame of the first job.
    I tried several times, every time with different setups like resolution, complexity and storage location.
    That’s just so frustrating…
    Can’t even get a clue where should I start to fix this problem.
    Anyone has some problem as mine?
    Nick
    Silver Siilak replied 12 years, 9 months ago 4 Members · 6 Replies
  • Nick Anderson
    September 17, 2011 at 2:53 am
    From something I noticed, I think I might found the reason cause this nasty 99% issue.
    In fact, there’s always one or two missing frames in the render sequence. Source image is fine, and missing frame location is random. The render batch freezes at 99% is in fact freeze at the missing one or two frames..
    Nick
  • Vivek Vedagiri
    September 17, 2011 at 4:17 am
    Hi Nick,
    Would you be able to send us logs and the exported project?
    You can capture logs using the Capture Logs application in /Library/Application Support/Blackmagic Design/DaVInci Resolve/. Running the app will create a log file on your Desktop. You may email them to davincihelp at blackmagic-design.com. Please capture logs as soon as the problem happens, and before restarting Resolve.
    Other information that would be useful to know:
    Does the render fail at a specific clip or is the failure random?
    Does the problem happen only in batch mode rendering?
    What format are you rendering to?
    What format is your source footage in?
    Vivek Vedagiri
    Blackmagic Design
  • Gabriele Turchi
    September 17, 2011 at 4:39 am
    i am getting the missing frames error quite often …
    mostly when the render exceed 10 minutes of footage …
    still haven;t figured out why , it random happen,,,,
    g
    Davinci Resolve Control Surface
    MacPro
    Cubix desktop 4
    2 Red Rocket
    GT120+GTX470+GTX285
    24GB RAM
    HD Dreamcolor
    Panasonic 58PF Plasma
  • Gabriele Turchi
    September 17, 2011 at 5:19 am
    hi vivev ,
    because i am getting the same error ,
    here my answers
    1)full random , sometimes i render , i get the error let say at frame 3455 , than i stop , (that by the way does not stop , you have to force quit) reopen render again and i get the error at frame let say 4152….
    2)it happen in batch or norma rendering mode
    3)it happened rendering QT
    4)happened different source in format : prores , R3D
    the error i get is : timeout , unable to decode frame xx, frame skipped ,,,
    g
    MacPro
    Cubix desktop 4
    2 Red Rocket
    GT120+GTX470+GTX285
    24GB RAM
    HD Dreamcolor
  • Nick Anderson
    September 19, 2011 at 3:28 pm
    Hi Vivek.
    As the problem happens random, I will capture the log as soon as it happens again.
    As far as I noticed
    the fail frames are random
    I’m rendering to DPX 10bits sequence
    Source is also DPX 10bits sequence
  • Silver Siilak
    December 4, 2013 at 7:42 pm
    I had a same thing. It’s kind of ridiculous what’s causing it and what’s the solution. Please take 1 minute to resolve this issue and go on with your editing/grading:
    https://nofilmschool.com/2013/11/background-rendering-premiere-fcpx-osx-mavericks-app-nap/
    Be well!
