Activity Forums Adobe After Effects alt+p for keyframe position not working
  • alt+p for keyframe position not working
    Posted by Evan b. Peters on March 12, 2013 at 3:01 pm
    Hello guys,
    Taking a course from Lynda in AE CS6. Everything’s been going very well. Today I encountered my first discrepancy with the instructions.
    I’m on chapter 4 lesson two of After Effects CS6 Essential Training, relating to keyframes.
    The instructor has me select 3 layers, place my cursor to the appropriate time and then press alt+p to set a keyframe for all the layers. Well, nothing happens. I have done a little research and haven’t found an answer yet. I am in the US on a US keyboard. As far as I can tell my alt key is working.
    I came to you guys because you have NEVER let me down. This place rocks, thanks again. I hope you can help me figure this out.
    Thank you
    Willie Frazier replied 13 years, 6 months ago 7 Members · 16 Replies
  • 16 Replies
  • John Cuevas
    March 12, 2013 at 4:03 pm
    Try shift+alt+P
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Ashish Gupta
    March 12, 2013 at 4:05 pm
    Evan,
    It’s shift+alt+p …
  • Paul Roper
    March 12, 2013 at 5:09 pm
    Hmmm…..alt + p works for me to add position keyframes.
    alt + s for scale keyframe, alt + r for rotation keyframe.
    – Paul
  • Evan b. Peters
    March 12, 2013 at 6:24 pm
    Thank you guys, very much, for the fast replies.
    I won’t be at my computer until later tonight. I will post the results of shift+alt+p then. Also I will give you exact course name and chapter (I gave a basic description in first post, btw.)
    Thanks again,
    Evan
  • Vishesh Arora
    March 12, 2013 at 8:30 pm
    Evan
    Even is the Documentation, It is what you have seen the tutorial. I have a tutorial of motion graphics from Lynda.com and the instructor used Alt + P though it was not the same in my case. As mentioned above by others, Shift key is missing in the combination. Don’t know how it works for them.
    From Adobe Documentation
    Add or remove keyframe at current time
    Alt+property shortcut
    Option+property shortcut
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    2011 3D Demo Reel:
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • Todd Kopriva
    March 12, 2013 at 8:47 pm
    As others have said, it’s Alt+Shift+P.
    There appears to be a mistake in the documentation that says that it’s just Alt+P.
    After Effects team blog
  • John Cuevas
    March 13, 2013 at 12:50 am
    Glad we could help.
    Thinkck.com
  • Evan b. Peters
    March 13, 2013 at 2:09 am
    Okay, I just tried it and yes, shift+alt+p does work for the intended purpose of setting the position keyframe.
    The exact course from Lynda which gave the wrong advice (amazingly) was: “After Effects CS6 Essential Training” with Ian Robinson, Chapter 4 lesson 2. The file name for the tutorial is: 04_02_Keyframes
    Thanks again, guys. You are absolutely the best support on the web that I know of.
    Evan
  • Evan b. Peters
    March 13, 2013 at 2:42 am
    He also makes another error in there saying alt+p for opacity keyframe when in reality it is shift+alt+p.
  • Paul Roper
    March 13, 2013 at 8:53 am
    I checked out that course, and yes, he definitely does say alt+p, but it totally works on my machine (a Mac running AE CS6: 11.0.2.11 and MacOS 10.7.5). If I have no layers selected, and press alt+p, it sets a position keyframe for all layers. If I have one or more layers selected, it sets a position keyframe for those layers. Same with alt+r for rotation, alt+t for opacity and alt+s for scale. Holding down shift achieves exactly the same result.
    Seems very odd that we’re getting different results.
    – Paul
