Activity › Forums › Adobe After Effects › alt+p for keyframe position not working
Willie Frazier replied 13 years, 6 months ago 7 Members · 16 Replies
Paul Roper
March 13, 2013 at 12:26 pm…so if any of you guys select a layer and then press alt+p, nothing happens?
John Cuevas
March 13, 2013 at 2:29 pmOn a PC(CS6), nothing happens with shift+(transform property), shift+alt+(transform property) does set at keyframe at the CTI
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
John Cuevas
March 13, 2013 at 6:06 pmI think I’ve tried every combination on a PC and the other way to get it to work as it should is alt+shift+(T,R,P,A,S)
Willie Frazier
March 13, 2013 at 6:23 pmConfirmed here that alt+P (or any other transform modifier such a R, T, or S) does most definitely create a keyframe on the Mac. It appears from what I have seen here that the behavior is different on a PC, however, and this difference is missing in the documentation which would explain why it is absent in the lynda course.
