Activity Forums Avid Media Composer Alternative to “nested” audio
  • Alternative to “nested” audio
    Posted by Adam White on April 9, 2014 at 5:28 pm
    I have several audio clips in my timeline that I have balanced against one another, but now would like to boost the overall volume of them as a group a touch.
    What is the easiest way to achieve this in Media Composer? In FCP7 I would probably have just nested them and adjusted the level of the nest accordingly. I am not familiar with “nests” existing in Avid (though fully expect I could be totally wrong on that), so what would an alternative method be?
    Thanks in Advance,
    Adam
    Adam White replied 12 years, 5 months ago 3 Members · 4 Replies
  • Ricky Barrow
    April 9, 2014 at 7:15 pm
    Audio Mix tool – you can boost entire channel using in/out marks and the hamburger menu, you can gang channels as well for functions.
    Ricky
  • Ricky Barrow
    There is also in MC 7 a “Master fader” for control over the entire timeline.
    Ricky
  • John Pale
    April 10, 2014 at 5:52 pm
    If it’s just a section, select the necessary tracks, set and in and out…then at the top of the mix tool, in the hamburger menu, select Adjust Pan/Vols In/Out. You can raise or lower then entire section a desired amount.
  • Adam White
    April 10, 2014 at 7:23 pm
    Thanks both. Master Fader worked great this time around.
