Activity Forums Apple Final Cut Pro Legacy alternative to h.264?
  • alternative to h.264?
    Posted by Mike Albertini on November 9, 2011 at 11:20 pm
    I need to export a 40 min video and send to colleague for checking and it will end up on the web for public viewing…
    I’m using h.264 as ive heard this is the best format for small file size but good quality
    Is there an alternative codec to h.264 as i’m suffering from its notorious gamma issues?
    Mike
    Jerry Hofmann replied 14 years, 10 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    November 11, 2011 at 2:38 pm
    I think the gamma issues are a QuickTime problem, and not an H.264 problem per se.
    So could you add a gamma adjustment filter in compressor or other compression software to fix your gamma shift, and stay with h.264?
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
