Activity Forums Adobe Premiere Pro Alternative to 40-50GB Per 5 Min. Of Premiere Pro Projects?
  • Alternative to 40-50GB Per 5 Min. Of Premiere Pro Projects?
    Posted by Rufus Napkin on February 25, 2010 at 2:32 am
    I try to archive a few <5 min. Premiere Pro projects originally shot in 1920 X 1080 HD, but all the codecs I've tried in Premiere when exporting (Uncompressed AVI, Quicktime Animation, MPG2, JPG2000) result in 35-60GB files. I would not know what to do with such files. The Windows Media codec works great for exporting to Youtube as it comes to less than 200-300MB and often much less. But for getting that lossless "Export to DV" - equivalent quality setting that is no longer available due to the nature of digital SD cards camcorders, I'm at a loss (no pun intended).
    A friend working on a MAC recently gave me a copy of a 10 min. short he'd shot at a same resolution. His Apple avi size was under 4GB!
    I understand there is the infamous 442 Apple codec that is not made for PC that I think he used. BUT... Is there some similar configuration I can use with the existing codecs in Premiere to archive my films without all that size?
    Is part of the answer in using MPEG Streamclip to shrink the 40-60GB files?
    OR, are there codes I can buy if they're not in Premiere to achieve this 4-5GB per 5min. of video goal of mine?
    And why doesn't Apple offer that 442 for Windows!
    Danny Winn replied 16 years, 6 months ago 2 Members · 1 Reply
  • Danny Winn
    February 25, 2010 at 2:32 pm
    If you select the HDTV 1080 preset (with whatever framerate matches your project) and the Mpeg2 output, your 5 minute project should be around 500 to 900 mb’s. My 30 second spots using these settings are around 68 mb’s and it’s beautiful Full HD.
