Activity › Forums › Apple Final Cut Pro Legacy › Alternate codec for chroma-keyed DV footage
  • Alternate codec for chroma-keyed DV footage
    Posted by Dawson Hunter on August 21, 2009 at 7:59 pm
    I am chroma-keying standard-def DV footage shot on a Panasonic DVX-100b. I’m working in FCP, and I am wondering if I might pull a better chroma key by first converting my DV footage into a different format (such as Apple ProRes 422).
    If so, can I just import my DV footage, and make my sequence an Apple ProRes sequence? I played around a little bit, but this project is on a time crunch.
    Dawson Hunter
    Video Editor – brass|MEDIA
    FCP / Motion / PS
    Rafael Amador replied 17 years, 1 month ago 4 Members · 3 Replies
  • John Fishback
    August 21, 2009 at 9:03 pm
    If you capture with a capture card in a 4:2:2 codec like ProRes or 8-bit uncompressed you might have better luck. I’m not certain if you’re locked out of 4:2:2 by recording DV. Try with a short segment and see. Also, you might want to do the key in Motion with Primatte. It’s a better keyer than FCP’s. Also, Keylight in AE is excellent.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • T. Payton
    August 21, 2009 at 11:28 pm
    One thing to remember is not to go back to DV after compositing your shots. Especially when you blur the chroma in Keylight (which is slow but fantastic) or other keyer. A straight transcoding to ProRez will not improve your shots going into the key but it will improve things on the way out.
    – T.
    T. Payton
    OneCreative, Albuquerque
  • Rafael Amador
    August 21, 2009 at 11:45 pm
    The Chroma filtering that you get on capturing to 422 (with the convenient capture card) should helps the keying.
    You may try as well Nattress “Chroma Smooth/Sharpen”, “Nicer” or similar.
    Cheers,
    Rafael
    http://www.nagavideo.com
