Activity Forums Adobe After Effects Alter adjustment layer’s mask path to match different frame rate?
  • Alter adjustment layer’s mask path to match different frame rate?
    Posted by Matthew Wood on May 17, 2015 at 5:20 am
    Hello. I keyframed an adjustment layer’s mask several thousand frames and didn’t realize, until after, that I had not interpreted the footage correctly to 23.976. So the keyframes on the mask layer are at 29.97.
    As soon as I correct the footage’s frame rate, it is all thrown off. I remember seeing something awhile ago regarding batch adjustment of keyframes but not sure how or if that can accurately match the correct frame rate. Thanks
    I just adjusted the layer’s speed and can see that that would work if anyone knows the exact percentage I need to make it to match 23.976 from 29.97. It has been way too long since I have had to use division for percentages, no idea how to do that, at moment.
    Blood type O negative. I bleed zeros and ones
    I dabble on the desktop
    Shifted Leering, Any Perspective
    Shifting Literally All Perceptions
    SLAP
    Matthew Wood replied 11 years, 3 months ago 2 Members · 2 Replies
  • Walter Soyka
    May 17, 2015 at 11:13 am
    [Matthew Wood] “I remember seeing something awhile ago regarding batch adjustment of keyframes but not sure how or if that can accurately match the correct frame rate. “
    Select the keyframes you want to modify in time and hold Alt while dragging the first or last in the range to proportionately expand or contract them.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Matthew Wood
    May 18, 2015 at 12:26 pm
    Ah, yes, thank you. I attempted the Alt drag with keyframes in the middle, somehow I missed that it had to be on end. Thanks, again,
    Walter, that is two for two.
    SLAP
