Activity › Forums › Adobe Premiere Pro › alt + shift replace problem, when there is speed change in clips.
  • alt + shift replace problem, when there is speed change in clips.
    Posted by Agris Čaurs on May 30, 2013 at 1:07 pm
    When there is a speed change for a clip in timeline, after replacing “alt+shift” way, i get offset, although clips are identical. So this feature becomes useless when I try to replace a clip wich speed/duration is set to 50%.
    maybe someone knows a workaround. Hope I explained good enough. If needed, i will create a video to show the problem.
    thanx 😉
    Weston Jones replied 9 years, 7 months ago 3 Members · 2 Replies
  • Ann Bens
    May 30, 2013 at 2:44 pm
    If I understand correctly, right mouse click on clip in timeline: replace with clip/from Source Monitor, Match Frame.
    You need to set the CTI in the correct place in the Source Monitor and in the timeline.
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
  • Weston Jones
    February 24, 2017 at 10:24 pm
    This doesn’t work for me when clips in the timeline have speed ramping changes to them. Is that right?
