Activity Forums Adobe After Effects Expressions Alpply while/do loop to a text layers, see no characters… why?
  • Alpply while/do loop to a text layers, see no characters… why?
    Posted by Assaf Goldlust on May 16, 2018 at 11:01 am
    Studying from the book “AE expressions”.
    I have reached the chapter about loops.
    In the book he applies the following expression.
    7
    The idea is to get a bunch of caharacters that change randomly wothing a certain range of ASCII code.
    I tried to do the same thing
    But for some reason my text layer gets completely blank.
    Any ideas for why and how to fix it?
    Assaf Goldlust replied 8 years, 3 months ago 2 Members · 13 Replies
  • 13 Replies
  • Dan Ebberts
    May 16, 2018 at 1:39 pm
    It looks like there are some extra spaces in there. Try it this way:
    posterizeTime(3);
    var myText = "";
    i = 0;
    while(i < 500)
    var randomNumber = random( 48 , 122);
    myText += String.fromCharCode(randomNumber);
    i++;
    myText
    Dan
  • Assaf Goldlust
    May 19, 2018 at 10:03 am
    still dont work
  • Assaf Goldlust
    May 21, 2018 at 2:59 pm
    i tried to do that with the code you wrote.
    but i still got the same result.
    please, i really need to understand why it doesn’t work and how to fix it
  • Dan Ebberts
    May 21, 2018 at 3:28 pm
    I just copied and pasted that code into the Source Text property of a text layer and it works as I would expect it to. What happens when you do that?
    Dan
  • Assaf Goldlust
    May 21, 2018 at 3:46 pm
    i recorded a video so you can see for yourself.
    https://www.youtube.com/watch?v=-bxgUiCEobQ&feature=youtu.be
  • Dan Ebberts
    May 21, 2018 at 4:01 pm
    That’s strange. So if you start with a text layer that has actual text, then apply the expression, same result?
    Dan
  • Assaf Goldlust
    May 21, 2018 at 4:03 pm
    yes, still same result 🙁
  • Assaf Goldlust
    May 21, 2018 at 4:06 pm
    it might be important to note:
    its happend to me also on another computer with a diffrent version of after effect.
    so i think we can rule out the possibility of a bug
  • Dan Ebberts
    May 21, 2018 at 7:36 pm
    Can you post a simple project file demonstrating the problem?
    Dan
  • Assaf Goldlust
    May 22, 2018 at 1:12 am
    Actually i was able to make it work.
    i dont knkw why yet but appearently its working great when im doing it on my CS6 version.
    so the problem is not with the expression.
    but there is another thing i wish to understand.
    in the book he stated that for this expressions
    my text need to have this variable
    var myText = "";
    but i still need to know why?
