Alpha Transparencies from Motion 5 to FCPX
The client wants to have the matte pulled so they can comp a person walking on to a webpage. They’d like me to pull the matte/key the subject and so they just have composite it.
I am having a bit of trouble with Alpha Channels. In Motion 5 I pulled the matte using the key filter. When I exported using share I made sure under Render that the Color+Alpha was enable and premultiply checked. Then I made sure it was ProRes 422 since I heard .H264 does not carry Alpha channels. I brought the .mov into FCPX and when I looked at the Alpha it was a solid color and most frustrating i could not comp the FG element over a BG by layering or connect to primary storyline.
Bringing the same video into Motion 5 did not work and seemed to not have a Alpha Channel which was really odd….I thought.
When you export Titles from Motion 5 it works great. I found a work around which was export Alpha only from Motion 5 then layer that over the FG in FCPX then choose in Composting Stencil Luma and connect the clips and bingo I’m rocking a BG behind the FG element.
Am I not finding the magic setting for export out of Motion 5 or is FCPX not reading an Alpha that does exist in the file. Compositing gurus please help.
