Activity › Forums › Adobe After Effects › Alpha renders look jagged
  • Alpha renders look jagged
    Posted by Victor Kohler on September 9, 2008 at 7:10 pm
    I’ve got some graphics made in AE rendered to Quicktime with the animation codec. The graphics have an alpha channel that needs to be preserved for compositing with live footage in FCP. The problem is that my renders look great when viewed in QT but in FCP they look bad. The edges get jagged the entire graphic looks unsharp. I’ve tried renders with other codecs like PNG and uncompressed with the same issues. Im editing in a ProRes HQ sequence in FCP. Im not shure if this is an FCP or AE issue, thats why im doubble-posting.
    Any ideas?
    Im using:
    Adobe After Effects CS3
    Final Cut Pro 6.0.4
    Quicktime 7.5.0
    /Victor Köhler
    Victor Kohler replied 18 years ago 3 Members · 4 Replies
  • Erik Pontius
    September 9, 2008 at 7:56 pm
    Make sure you are using “straight” alphas rather than “pre-multiplied” alphas in your renders.
  • Jason Milligan
    September 9, 2008 at 8:13 pm
    Also, make sure you are probably interpreting the alpha channel once you bring it into Final Cut.
  • Jason Milligan
    September 9, 2008 at 8:41 pm
    I meant “properly interpreting”
  • Victor Kohler
    September 10, 2008 at 7:59 am
    Now it works! My animation codec still looks bad but when i rendered it as a PNG sequence with pre-multiplied alpha and set the alpha interpretation in FCP to black it turned out very nice! Thanks for the help guys!
    /victor Köhler
