Activity › Forums › Adobe Premiere Pro › Alpha Problems
Alpha Problems
Posted by Paul Rozon on December 29, 2011 at 8:23 pmOn my timeline I have 2 video tracks. Track 1 is my main content and Track 2 (above track 1) I have placed a video that has an alpha.
All looks good and renders out fine.
I then added a “levels effect” to Track 1 and instantly my alpha looks like a bag of hammers. If you mute the effect the alpha goes back to normal.
Any Idea of what I am running up against here?
Any input would be appreciated.
Paul
Alex Udell replied 14 years, 9 months ago 3 Members · 16 Replies -
Alex Udell
December 29, 2011 at 8:50 pmMercury enabled Levels control or regular old software one?
Alex
Alex Udell
December 29, 2011 at 9:40 pmIs it possible to test it with the non mercury version?
I’m merely guessing…
Alex
Alex Udell
December 29, 2011 at 10:53 pmIf you look in the effects panel…you can sift the listings to show you accelerated or non accelerated versions of fx. I may be wrong about that….As I’m not in front of it, I can’t verify…
Alex
Tom Daigon
December 29, 2011 at 11:20 pmAre you running a CUDA approved card (I.e., Nvidia 4000)?
Tom Daigon
Avid DS / PrP / After Effects Editor
http://www.hdshotsandcuts.com
Mac Pro 3,1
8 core
10.6.8
Nvidia Quadro 4000
24 gigs ram
Maxx Digital / Areca 8tb. raid
Kona 3 -
Paul Rozon
December 30, 2011 at 4:55 pmHere are the tech specs. Hopefully this helps.
System/Software
HP Z400 Workstation
Matrox MX02LE
Windows 7 Profesional – Service Pack 1
12Gb RAM
Adobe Production Bundle Suite 5.5
NVideo Quadro 4000Sequence Preset
Matrox – HD 1080i @ 29.97Source Media Vid Track 02
After Effects composition – 1080 x 1920 @ 29.97
lower third scrolling text
Rendered as – Matrox AVI uncompressed RGB + AlphaSource Media Vid Track 01
Line Cut – Panasonic HS400 Switcher
Recorder – Panasonic P2 Recorder AJ-HPD2500P
AVC-I 100 @ 1080i 60In PP I have source media on track 1 and AE lower third scrolling text on Track 2 (above track 1). Everything looks prestine on PP program monitor and on external production monitor. Export timeline and severe banding occurs.
I have attempted exporting AE file in a number of different file types without any difference. I have also attempted exporting PP sequence in a number of different files types without success.
Paul Rozon
December 30, 2011 at 4:59 pmto clarify…
Originally I thought the Levels Effect was causing the problem so I removed the levels effect and rendered the timeline to find the same problem with the banding.
Alex Udell
December 30, 2011 at 6:40 pmHow about something other than Matrox code? Quicktime Animation + Alpha?
Alex
Paul Rozon
December 30, 2011 at 6:46 pmYup, Tried Animation with Alpha and a slew of others with the same result which leads me to believe it is a premiere issue.
