Activity › Forums › Adobe After Effects › alpha plugins help
  • Kevin Camp
    February 22, 2007 at 5:32 pm
    since the plugin is called firtree, i’m betting your stuck with needles… write to them and express interest in a plugin called deciduoustree and they may create one… or maybe just ‘tree’ and you can pick the foliage.
  • Mylenium
    February 22, 2007 at 7:29 pm
    Well, depending on what you are looking for, you could achieve it all with expression based setups or by using a particle system. If you could provide a reference picture of what look you are actually after, we might help you out on that.
    Mylenium
    [Pour Myl
