Activity › Forums › Adobe After Effects › Alpha matte problem CS6
Posted by Ellen Pollard on February 19, 2013 at 10:08 amHi!
When I alpha matte an object in cs6 there is still a thin line visible of the lower object, on the edges (sorry if confusing 🙂 )
I could draw a mask , but the upper objects are sometimes complicated.
Does anyone know a way to fix this?Thanks a lot!
Vishesh Arora replied 13 years, 7 months ago 4 Members · 7 Replies -
Tudor “ted” jelescu
February 19, 2013 at 10:16 amCan you post a still/screen grab of the issue- a picture is worth 1000 words…
Tudor “Ted” Jelescu
Senior VFX Artist -
Tero Ahlfors
February 19, 2013 at 10:24 am[Ellen Pollard] “there is still a thin line visible of the lower object”
Well is your matte big enough?
Ellen Pollard
February 19, 2013 at 10:26 amIt’s a bit hard to see like this, but there’s a very thin line around his body. It appeared when i alpha matted a texture with the illustrator shape of his body.
thanks! -
Ellen Pollard
February 19, 2013 at 10:28 amThe texture underneath is bigger than the shape above, if that is what you mean
Tudor “ted” jelescu
February 19, 2013 at 12:26 pmHow are you using the shape as a matte- track matte or using Channel filter?
Tudor “Ted” Jelescu
Senior VFX Artist -
Vishesh Arora
February 19, 2013 at 2:27 pmEllen
Try using Remove Color Matting Effect.
Though it helps when we use effects that creates transparency but you can give it a try as Alpha Track Matte also creates the transparency.
Vishesh Arora
3D and Motion Graphics Artist
Films RajendraBlog:
https://digieffects.wordpress.com2011 3D Demo Reel:
https://www.youtube.com/watch?v=lHPgIJU_BR8
