Activity Forums Apple Final Cut Pro Legacy Alpha Matte / Luma Matte Problem
  • Alpha Matte / Luma Matte Problem
    Posted by Jason Griffith on April 25, 2007 at 2:46 pm
    Hey there,
    I’ve created a transition in AE to be used in Final Cut. In order to make it work, it needs to utilize the Alpha Matte or Luma Matte function to Cause “Video A” to Scale down while “Video B” is revealed. Everything works great. The only problem is that when “Video A” has some effects on it, for some reason when it goes over the matte the effects get slightly changed. Mainly for color correction. Is this because the matte is white and FCP’s Mattes are using a special blend mode that is adding or subtracting the pixels? Is there a solution? I can find a work around on a case by case basis. However, this is going to be part of permanent gfx package that will be used several times a week. It needs to be more streamlined. Any thoughts?
    Jason Griffith
    Broadcast Editor
    The Active Word
    “An Unexamined Life Is Not Worth Living” – Socrates
    Arnie Schlissel replied 19 years, 5 months ago 2 Members · 1 Reply
  • Arnie Schlissel
    April 26, 2007 at 11:49 pm
    My 1st guess is that this is a typical YUV vs RGB type of thing. Check your sequence settings, & toggle the YUV/RGB render & see if that changes anything.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
