Activity › Forums › Zaxwerks › Alpha Key output…
  • Alpha Key output…
    Posted by Tim Baker on January 12, 2010 at 5:50 pm
    Ok…so I finally got a pseudo animation to test with and when I bring it into FCP…I get no alpha even though the check box is checked in PA…and I put over a hard black background…any ideas on this one?
    Edward Wu replied 16 years, 8 months ago 2 Members · 1 Reply
  • Edward Wu
    January 13, 2010 at 1:21 am
    Hi guys,
    We resolved this issue, but in case anyone is running into the same issue, be sure that you do not use a compression type such as DVC, HDV, MPEG, JPEG or any other that does NOT support an alpha channel. If you are rendering to a QuickTime movie, the compressor must be set to “Animation” and “Millions of Colors+”. The “+” means it will render with the Alpha Channel. If you render out in AVI format, use the Uncompressed option.
    Best,
    Edward
