Activity Forums Adobe After Effects Alpha Inverse Matte with 3D Layers
  • Alpha Inverse Matte with 3D Layers
    Posted by Dan Pinto on March 19, 2011 at 3:08 pm
    I’m having an issue with an Alpha Inverse Matte on a 3D layer.
    My project is set up with 3 3D solids, one in front of the other, and a light centered on the top one. When I mask the top layer normally, pen tool, the light treats the mask like a window, shining through it. This is the effect I want.
    However, I’m trying to create this effect with a type layer so, I used an Alpha Inverse matte on the front solid. The problem is that the light doesn’t see the Alpha matte as a “window.” Instead, I get a hole in the solid but the shadow cast by it is the shadow of the whole solid.
    I included a picture:
    https://iheartdan.com/Mask_Problem.jpg
    On the left is the alpha matte on the right is the pen tool mask. Notice that the alpha matte still casts a shadow, while the pen tool mask does not. I’d like the alpha matte (left) to behave like the pen mask (right). Help?
    EDIT:
    NEVERMIND. I figured it out.
    -Dan
    Dan Pinto replied 15 years, 5 months ago 2 Members · 2 Replies
  • Chris Buttacoli
    March 19, 2011 at 11:00 pm
    You should let the forum know how you figured it out so it can show up if someones else searches a similar problem.
  • Dan Pinto
    March 22, 2011 at 1:45 pm
    Oh. Sorry about that.
    It seems so obvious now but, I just pre-comped the solid with the matte layer and treated that comp as a 3D layer. Then, I could animate all I wanted within the pre-comp and the result would look as I wanted.
