Activity Forums Adobe Premiere Pro Alpha channels and masking … Is this me or a glitch?
  • Alpha channels and masking … Is this me or a glitch?
    Posted by Steve Dann on April 9, 2017 at 5:45 pm
    Trialing Premiere Pro CC and have come across two issues.
    1. I occasionally need to export a pre-keyed clip for someone else to drop over a background. The ProRes 4444 exported from PrPro CC works in FCP 7 but behaves strangely when re-imported into PrPro CC. With the file in the project panel, if I go to ‘interpret footage’ the alpha channel settings are greyed out although ‘ignore alpha’ is unchecked. Occasionally, for no apparent reason, the alpha settings are available …? Anyway, if I add the ProRes 4444 clip to a timeline over another clip the transparency is there EXCEPT after a few seconds, even if I don’t touch anything, the background disapppears, its as though PrPro has ‘forgotten’ the alpha channel ! If I delete the clip from the timeline and add again, there is no transparency BUT if I delete the clip from the project panel and re-import, when I add it to the timeline again the transparency is there again for a short time … got to be a bug hasn’t it ?
    2. Other problem that’s just started, is that I can add a mask path and see the shape but it doesn’t actually cut a hole !
    I hope I’m making a daft mistake, or two, or is PrPro relly this flaky ?
    Thanks in advance …
    Steve Dann replied 9 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
