Activity › Forums › Maxon Cinema 4D › Alpha Channel not saved
  • Alpha Channel not saved
    Posted by Carlos Lopez on June 17, 2008 at 2:28 am
    HI…
    Im rendering a tiff sequence with alpha..howver, when the frame render is done.. only a few object with in th scene keep the alpha…whiel it renders all objects have it…. but then it gets wipped out… i have no bufferes… and my render settings are as follow…
    tiff
    32 bit
    Alpha channel checked
    24 bit dithering
    Please help!
    thnks
    Randy Johnson replied 18 years, 3 months ago 2 Members · 1 Reply
  • Randy Johnson
    June 17, 2008 at 6:06 am
    If you are rendering with out buffers every object shares the same alpha. Can you post a still or scene file?
    /randy
