Activity › Forums › Apple Final Cut Pro Legacy › alpha channel issues
Posted by Glen Perez on May 5, 2009 at 1:52 pmhi, im exporting tga secuences from after effects, then import them into fcp, but we are getting a white line in the alpha borders… what is the problem?
Jeremy Garchow replied 17 years ago 3 Members · 3 Replies -
Russell Lasson
May 5, 2009 at 2:33 pmTry changing the render settings to “straight” from “premultiplied”.
-Russ
Russell Lasson
Universal Post
Ridgeline Digital Cinema Mastering
Salt Lake City, UT -
Jeremy Garchow
May 5, 2009 at 4:56 pmYou have to tell FCP which alpha channel render you used. In the browser, scroll to the column that says alpha channel and set it to Black or Straight. AE defaults to premultiplied with black, so if you didn’t change the render settings in AE, then choose ‘Black’ in FCP. If the movie is already in your timeline, you will have to change it there too by right clicking on the movie and then choosing item properties > format and choose ‘Black’ for Alpha. If you have rendered a straight alpha, choose straight. After you change it in the browser, you can simply replace the one in the timeline as well.
Jeremy
