Activity › Forums › Apple Final Cut Pro Legacy › Alpha Channel Issue FC 6
  • Alpha Channel Issue FC 6
    Posted by Jekabs on June 7, 2007 at 10:31 am
    Hello.
    I have just updated my
    Intel Xeon 2x3GhZ Dual Core
    6 GB RAM
    Black Magic Multibridge Extreme
    to final cut studio 2.
    and I found out following issue:
    when i add a filter (Flicker Filter or Collor Correction filter or a drop shadow) to a movie with aplha channel, it (alpha channel) dissapears and where it should be transparent – it stays black.
    Jekabs
    Tom Wolsky replied 19 years, 3 months ago 3 Members · 3 Replies
  • Rafael Amador
    June 7, 2007 at 10:56 am
    Hi Jekabs,
    I haven’t see that in FC, but there is an issue when aplying effects to movies with Alpha.
    In AE and Shake if you want to CC a picture with Premultiplied Alpha, you must to de-Multiply the clip before to apply the filter, otherwise the effect affect the Alpha channel too.
    I don’t know if is the same issue. What kind of Alpha it got your pictures?
    Cheers,
    rafael
  • Jekabs
    June 7, 2007 at 11:23 am
    No, i think there is another kind of issue.
    I am using movies with black alpha channel (like always). But in FC 5 there wasn’t any problems when applying, for example – flicker filter or adding a drop shadow to movie. But now there is a problem. As i said in previous post – alpha channel dissapears (stays black where it should be transparent) when I add a drop shadow (not filter, but in movie controls) or any other filter.
    Jekabs
  • Tom Wolsky
    June 7, 2007 at 3:24 pm
    Please be specific on the material you’re using and the settings you’re using. This may be specific to your hardware and media you’re working in.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
