Activity › Forums › Maxon Cinema 4D › Alpha Channel inverted suddenly C4D
  • Steve Bentley
    August 4, 2017 at 7:31 pm
    Ok I have that frame alphaing now. I simply increase the smoothness of the camera path from 5 down to 2.
    Also of note (and where the hiccup was) you have a broken handle on the spline as it turns upward. you can fix that by selecting that point on the spline and choosing mesh/spline/softinterpolation .Then you can adjust it to be the angle to want and you will get a smooth transition from horizontal to your upward curve.
    https://i1.creativecow.net/u-upload.php#
  • Agusriady Saputra
    August 6, 2017 at 4:28 pm
    Steve Bentley its fixed the issue, Thank you so much!!!!!! I really Appreciate it. the spline was the only problem.
Page 2 of 2
