Activity › Forums › Avid Media Composer › Alpha Channel into Avid
Posted by Rob Roams on September 10, 2007 at 4:47 pmHi,
IRob Roams replied 19 years ago 3 Members · 3 Replies -
Matthew Kasey
September 10, 2007 at 5:07 pmcheck your feathering settings in Photoshop. It may be up a little high, and be giving you too much area around your matte. You said you could see the trim in Photoshop right?
Michael Hancock
September 10, 2007 at 5:20 pmForget tiff files. Use png–you won’t have to make an alpha channel.
Cut your object out and put it over a transparent background in Photoshop (the checkerboard). Don’t bother making an alpha channel–just save it as a .png. Import into Avid with Invert Alpha and you should be good to go. Avid will interpret the checkerboard “transparency” as your alpha, and it should do it without the white edge.
This has always taken care of the white “ghosting” from other formats that require you to create an alpha channel (tiffs, targas, etc…).
Michael.
Rob Roams
September 10, 2007 at 8:08 pmThank you for the fast responses. You are right the .PNG files work great.
THANK YOU!!
