Activity Forums Apple Final Cut Pro Alpha channel in Preview
  • Alpha channel in Preview
    Posted by John Godwin on April 3, 2014 at 4:44 pm
    I frequently create an alpha channel on a still graphic in Preview, using the magic wand. Sometimes when I do this and import the still into FCP X the alpha channel work but the still image is semi-transparent too. There’s no indication of bad selections in Preview.
    I’ve checked all the settings in the FCP X inspector and all seem normal.
    If I duplicate the image on the timeline and stack it over the original it appears solid. So, any ideas as to what I must be doing wrong? Maybe in Preview?
    Thanks.
    Best,
    John
    John Godwin replied 12 years, 5 months ago 2 Members · 2 Replies
  • Bret Williams
    April 3, 2014 at 9:25 pm
    Hey John,
    That’s a nice trick in Preview. I didn’t know about that. So I can’t help you there. But I’ve been playing with Pixelmator and I like it a lot as a Photoshop replacement. Only $30 or so in the app store. You’d have a bit more control.
  • John Godwin
    April 3, 2014 at 10:05 pm
    Someone showed me that a couple of years ago. It’s very quick and easy. If only I can figure out why *sometimes* it does this thing …
    Best,
    John
