Activity Forums Apple Final Cut Pro Legacy Alpha Channel from AE into FCP
  • Alpha Channel from AE into FCP
    Posted by Christian Heilman on February 11, 2010 at 10:14 pm
    I was wondering how I could take an Alpha Channel effect into Final Cut Pro. Essentially I will have someone export a page ‘peel’ out of After Effects. I would like to have that ‘peel’ reveal an end page that I currently have in a sequence in FCP.
    Working w/ FCP 6 and AE CS3
    thanks
    Alex Elkins replied 16 years, 7 months ago 4 Members · 3 Replies
  • Michael Gissing
    February 11, 2010 at 10:27 pm
    If AE is on the same computer as FCP 7 then you have a new choice of ProRes 4444 which has an alpha channel.
    With FCP6 you have animation codec which also has an alpha channel.
  • Stephen Smith
    February 11, 2010 at 11:25 pm
    If using the Quicktime, Animations codec be sure to set it to Millions of Colors +. The + stands for the alpha channel.
    Utah Video Productions
    Check out my Motion Tutorials
  • Alex Elkins
    February 11, 2010 at 11:26 pm
    Hi Christian,
    Make sure you select Millions of Colors+ in your render settings (the ‘+’ stands for plus alpha)
    The default is just Millions of Colors.
    All the best,
    Alex Elkins
    Salad Daze Films – Freshly Tossed
    Read my blog!
