Activity Forums Maxon Cinema 4D Alpha channel for lens flare
  • Alpha channel for lens flare
    Posted by Graham Quince on November 5, 2008 at 11:08 am
    Hi everyone
    Wondering if you can help. I’ve created an object with a light on it, with the lens flare effect activated and need to be able to isolate the object from the background.
    I added a compositing tag to the object, (the light is a child of it) and rendered out including a matte multipass, but unfortunately, the matte hasn’t taken into account the lens effect.
    Is there any way around this, or should i always add lens flare on in After Effects?
    Graham
    https://www.shiveringcactus.bravehost.com – Free FX for amateur films
    Graham Quince replied 17 years, 10 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    November 5, 2008 at 4:31 pm
    You can add “lens effects” to the multipass render which will give you the flare on a black background. Then you can multiply it over your object … or not, as you prefer.
  • Graham Quince
    November 5, 2008 at 9:16 pm
    That’s brilliant, thanks Adam
    Graham
