Activity › Forums › Adobe After Effects › Alpha channel and FLV
Posted by James Ledford on April 10, 2009 at 8:37 amI have rendered a logo from C4D with all the goodies. Then imported the logo into AFcs4. All the goodies work, however when i render a FLV file, no alpha. The final logo is to be passed on for use in Dreamweaver with a transparent background. I have looked throught the tutorials and forms, what am i missing?
Chris Wright replied 17 years, 5 months ago 4 Members · 10 Replies -
Nicolas Hansen
April 10, 2009 at 2:41 pmHave you tried going to “Format Options” after you’ve selected FLV from the dropdown menu in the output module? Inside “Format Options” is a checkbox with an option to encode the alpha channel (under Basic Video Options)
After you’ve checked the box, make sure that you have “RGB + Alpha” selected in your channels under the video output.
Hope this helps. -
Jeremy Allen
April 10, 2009 at 4:38 pmThe FLV codec also needs to be OnVP6 to include an Alpha channel.
8core MacPro, 3.0 GHZ, 10GB RAM, OSX 10.5.2AE CS3
James Ledford
April 10, 2009 at 7:42 pmyes, i have the output set to 32 bit, using the on2 vp6, encode alpha, vbr two pass, key frame set to 15.
In ae, the mask file is on top of the logo, the logo is the parent, and the mask is set to luma. The mask works in ae, i can change the bg. ect. The flash file when imported into either primere or flash does not have an alpha.
thank you for the responses.
Chris Wright
April 10, 2009 at 8:32 pmrender straight and AE interpret straight alpha not premultiplied
James Ledford
April 10, 2009 at 9:00 pmi have just rendered as straight not premultiplied. I am new to this software. under main options i only see color – straight unmatted. is this what you mean by render straight?
thanks
Chris Wright
April 10, 2009 at 9:29 pmDid you render premultiplied before and are just now testing straight alpha=(color – straight unmatted)?
James Ledford
April 10, 2009 at 9:39 pmyes, i have just finished a test in flash. still no alpha channel. when i inport into flash i import video with an external player no skin. place a solid bg (differnt color from ae render).
i changed the mask in ae from lumin to alpha thinking that was the issue but still no luck.
does anyone know of a tutorial on this topic. i know i am missing somthing, just too new to ae, flash and dreamweaver to figure it out.
thanks
Chris Wright
April 10, 2009 at 10:17 pmuse the separate adobe media encoder and edit export settings -“encode alpha channel”. bam! AE now has RGB+alpha.
James Ledford
April 13, 2009 at 4:15 pmThanks for the help. I still am unable to get this to work. I used media encoder cs4, loaded in an ae project and encoded a flv file with an alpha, imported into flash with the same results.
thanks
James
Chris Wright
April 13, 2009 at 10:41 pmThere is something wrong I think, but in the meantime, export out full uncompressed using this guideline and import directly into flash as a workaround until you get this resolved.
https://kb.adobe.com/selfservice/viewContent.do?externalId=tn_12837&sliceId=2
