Activity › Forums › Apple Final Cut Pro Legacy › Alpha channel
Alpha channel
Posted by Kaiserstrasse on March 3, 2007 at 1:06 amI’m exporting files out of After Effects 7 into a Final Cut Pro timeline and I can’t get Final Cut to read the Alpha chanel I’ve created in After Effects.
I’m using an Animation codec, million colors+, and have tried both straight and pre-multiplied. The file imports with a black background no matter
what I do. Yes, I’ve tried the various Alpha views in the menu bar as well – any help greatly appreciatedcheers
Bret Williams replied 19 years, 6 months ago 5 Members · 6 Replies -
Ben Holmes
March 3, 2007 at 1:27 amYour alternative is to output the alpha channel as a matte. Drop into layer below the rendered comp and set comp layer (in FCP) composite mode to ‘travel matte luma’.
Just mention it if you’re struggling and up against it. FCP has some issues dealing with Alpha channels (exporting particularly), but the method you describe SHOULD work. I would check the After Effects export settings again – as I am sure you have already…
Ben
Editec Broadcast Editing Ltd
EVS & FCP specialists for live OB operations.
New HD edit/slomo truck on the road this month. Dual FCP systems/6 slomo positions.
Kaiserstrasse
March 3, 2007 at 1:40 amBen – thanks for your help. I’ll give that a try, but I’m sure I’m just missing a setting somewhere, as I’ve done this before with no problems
KB
David Roth weiss
March 3, 2007 at 2:32 amFor many reasons you’d be better off importing a 32-bit TGA sequence.
Chris Borjis
March 3, 2007 at 4:33 am[David Roth Weiss] “For many reasons you’d be better off importing a 32-bit TGA sequence”
David can fcp import a sequence now properly?
I thought you had to build a quicktime out of a .tga sequence to get them to play nice.
I’ve also used motion to do that.
David Roth weiss
March 3, 2007 at 8:00 amYowser Chris,
It works just fine for me. I’ve always been a big fan of Targa sequences because you only have to fix the parts that need fixing and render just those frames that need to be rendered.
All the best,
DRW -
Bret Williams
March 3, 2007 at 8:07 amThere’s no need to re render an entire quicktime file either. It is an editing machine after all. Just rerender the frames or seconds neccessary and insert them into the quicktime. If you want a nice concise quicktime that’s not broken into parts, just edit the parts together and export a self contained file. There’s no further compression. I find the benefits to enormously outweigh any downsides. What a hassle to have a computer drive full of image sequences imho. With a drive full of quicktimes I just open them up in quicktime, or even in column view without opening a single app. They show up in searches and spotlight.
