Activity › Forums › Boris FX Particle Illusion › alpha
Posted by Bam Ross on June 19, 2005 at 7:32 pm
what output settings can i use to achieve a transparent back ground…..help…!!
advance in harmony…..BAM
Alan Lorence replied 21 years, 3 months ago 4 Members · 5 Replies -
Elvis Deane
June 19, 2005 at 8:21 pmAfter you hit the render button, make sure to select a format that supports an alpha channel (PNG, TIF, TGA, and a few others). AVIs out of pI don’t export with alpha channels at this time.
Once you’ve picked a format that alphas will work with, the Save Alpha box should be checkable on the Render Settings page.
Elvis Deane!
The particleIllusion FAQ
particleIllusion Resources and tutorial CD
Astounding Adventures -
Bam Ross
June 19, 2005 at 8:57 pmdoes that mean I will have to use an image sequence ?? Is there a way to export an .mov with alpha..??
I’ve tried exporting as animation with millions of colours + but no luck.Thanks for the info Elvis
Aharon Rabinowitz
June 20, 2005 at 12:45 amright now it has to be an image sequence. But if you really need to have a MOV with alpha, you could always import the Tiff, TGA, or PNG sequence into a program like After Effects or a NLE like Vegas, and then output the quicktime with alpha (Straight, not premultiplied).
That’s the solution I use. But usually I just use an image sequence – most programs don;t see it any differently than an MOV or AVI.
Aharon Rabinowitz
aharon(AT)yahoo(DOT)com
http://www.allbetsareoff.com
Creative Cow Master Series DVD
particleIllusion Fusion Volume 1
available @ http://www.pIllusionFusion.com -
Bam Ross
June 20, 2005 at 12:58 am -
Alan Lorence
June 20, 2005 at 2:59 amIf you’re using pIllusion SE on OS X, then you can save a Movie with alpha. Just make sure you choose a compressor that supports alpha (such as “animation”) and make sure you choose the highest number of colors.
Alan.
wondertouch
