Activity Forums VEGAS Pro alpa ch.to get to vegas 9
  • alpa ch.to get to vegas 9
    Posted by Fred Bargnare on August 13, 2009 at 12:12 am
    how do I get to the alpha ch. in particle illusions so I can try to send effects to vegas 9?
    John Rofrano replied 17 years ago 2 Members · 1 Reply
  • John Rofrano
    August 13, 2009 at 12:29 pm
    The easiest way to maintain the Alpha Channel from particleIllusion to Vegas is to output from particleIllusion as a PNG sequence. (i.e., a sequence of still images in the PNG format with an alpha channel.) Make sure that you check the option in PI to include the alpha channel. Then in Vegas use File | Import I Media then select only the first image in the sequence and check the box at the bottom of the Import Media windows that says: [X] Open still image sequence. Vegas will interpret the images as a video event with an alpha channel.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
