Activity Forums Adobe Premiere Pro Almost there! I’m exporting my video to be finished but audio track is seperate. CS4
  • Almost there! I’m exporting my video to be finished but audio track is seperate. CS4
    Posted by Mark Havens on September 18, 2009 at 3:44 am
    HEllo,
    I’m just finishing up my project. I’m having really bad interlacing issues when I export so I went to my time line right clicked on all the video pieces went to field options and selected the Never interlace option.
    Now, when I export the only format that gives me a clean picture is MPEG2-dvd and but the problem is the audio is being exported as a separate file.
    Is there anyway to stop that?
    I’m using PP cs4.
    Thanks in advance!
    -Mark
    Robert Westendorp replied 16 years, 11 months ago 3 Members · 2 Replies
  • Brian Louis
    September 18, 2009 at 7:37 am
    [Mark Havens] “MPEG2-dvd and but the problem is the audio is being exported as a separate file.”
    If you want a combined file make sure you have multiplexing selected, just open the multiplexer tab thats below the export settings, if multiplexer is set to “none” it will export Elementary Streams.
  • Robert Westendorp
    September 18, 2009 at 3:33 pm
    If you want you can use another tool like FormatFactory to “mux” the video/audio track back into a single file.
    If you’re taking the files and making a DVD just add both assets into the appropriate places and it’s all good 🙂
    Robert.
