Activity Forums Apple Final Cut Pro Legacy allpy effect to entire track
  • allpy effect to entire track
    Posted by Gabriele Gismondi on May 15, 2010 at 6:09 pm
    hi, just fineshed my CCorrection to the sequence.
    now i’d like to apply a widescreen effect to all clips..should i add it clip by clip or is there a way to apply a new effect to intire track? i tied with PASTE ATTRIBUTES but it cleans up the previous effect set to the clips.
    tnx for help
    Gabriele Gismondi replied 16 years, 4 months ago 4 Members · 4 Replies
  • Joseph Holder
    May 15, 2010 at 6:24 pm
    hello, you can easily apply an effect to one clip, then select all the clips except that one with command a
    then just drag the effect from the preview window. hope it works!
  • John Pale
    May 15, 2010 at 6:25 pm
    Nest the sequence. Add the effect to the nest.
  • Arnie Schlissel
    May 16, 2010 at 3:26 am
    You can drop a slug over the entire sequence & use a garbage matte as your widescreen matte.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Gabriele Gismondi
    May 16, 2010 at 9:32 am
    thank to all, im trying your tips..tnx
