Activity Forums Adobe After Effects allocating memory?
  • allocating memory?
    Posted by Paul Baker on February 4, 2008 at 9:25 pm
    Hey guys! I just talked to the head apple representative from St. Louis about how freakishly slow my mac works when I’m working with AE cs3. And she said that I should look into allocating more memory to AE. Does any one have any idea how to do this?
    By the way, I have the updated GridIron Nucleo Pro and it isn’t rendering at all, and I can’t get AE to render out either. I know that I have a complex 3d composition that I’m working with, and I planned on it being a while to render out. But it’s not rendering out even a couple seconds worth…
    any clues?
    Thanks a bunch,
    Paul
    SPECS:
    Model Name: Mac Pro
    Model Identifier: MacPro2,1
    Processor Name: Quad-Core Intel Xeon
    Processor Speed: 3 GHz
    Number Of Processors: 2
    Total Number Of Cores: 8
    L2 Cache (per processor): 8 MB
    Memory: 16 GB
    Darby Edelen replied 18 years, 7 months ago 3 Members · 12 Replies
  • 12 Replies
  • Jason Milligan
    February 4, 2008 at 9:34 pm
    You didn’t recently upgrade Quicktime by chance, did you?
  • Paul Baker
    February 4, 2008 at 9:36 pm
    I did upgrade to Quicktime 7.4, but I took care of it with Pacifist last week, so I’m pretty sure that’s not the issue.
    It’s funny that when I try to render out just “nothing” happens.. no errors, nothing..
    SPECS:
    Model Name: Mac Pro
    Memory: 16 GB
  • Darby Edelen
    February 4, 2008 at 9:46 pm
    [Paul Baker] “It’s funny that when I try to render out just “nothing” happens.. no errors, nothing..”
    Does AE act as though the render finishes? Does it quit unexpectedly? Does it never even try to start rendering? Can you give more details?
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Paul Baker
    February 4, 2008 at 9:54 pm
    Hey Darby!
    Yea, it looks as though it never even tries to start, it literally stays at 0% with the pinwheel spinning for hours with a 3 second clip to be exported.
    “Does AE act as though the render finishes? Does it quit unexpectedly? Does it never even try to start rendering? Can you give more details?”
    SPECS:
    Model Name: Mac Pro
    Memory: 16 GB
  • Darby Edelen
    February 4, 2008 at 9:58 pm
    Could you post your Memory & Cache settings from AE’s preferences? Do you have Multiprocessing enabled?
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Paul Baker
    February 4, 2008 at 10:48 pm
    My memory and cache preferences are
    Max Memory Usage 120 % = 3.0 GB
    ImageCache
    Max RAM Cache Size 49.4 % 1.5 GB
    Enabled disk Cache
    Max Disk Cache Size 20000 MB
    and I don’t have Multiprocessing on, because I have Gridiron Nucleo Pro installed, and it is required that I unselect Render Multiple Frames Simultaneously.
    SPECS:
    Model Name: Mac Pro
    Memory: 16 GB
  • Darby Edelen
    February 5, 2008 at 12:10 am
    [Paul Baker] “and I don’t have Multiprocessing on, because I have Gridiron Nucleo Pro installed, and it is required that I unselect Render Multiple Frames Simultaneously. “
    Perhaps you should try disabling Nucleo Pro and seeing how your renders behave.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Paul Baker
    February 5, 2008 at 5:16 pm
    Ok,
    I took off Gridiron Nucleo Pro, and enabled the Multiprocessing option in the preferences. I let it try to render out a 4 second clip over night. It said it wanted four hours to do it. So when I got in this morning After Effects was frozen, with 3 minutes to go.
    Any idea why this is happening?
    Paul
    SPECS:
    Model Name: Mac Pro
    Memory: 16 GB
  • Paul Baker
    February 5, 2008 at 5:37 pm
    Hey Dave,
    I am pretty sure I have everything taken care of. My About Quicktime player says QuickTime™ Version 7.3.1, Player Version 7.3.1 (7.3.1). Which I did by using Pacifist to re-install 7.3. Is there anything else I need to look into?
    SPECS:
    Model Name: Mac Pro
    Memory: 16 GB
  • Paul Baker
    February 5, 2008 at 6:01 pm
    Hey dave any ideas on where I can get the list for the certain manufactures for memory? My tech guy got us this cheap third party RAM, and he really doesn’t know anything about macs, so that’s what I’m guessing.
    SPECS:
    Model Name: Mac Pro
    Memory: 16 GB
