Activity › Forums › VEGAS Pro › All the key frames for video fx changes when I change only one.
  • All the key frames for video fx changes when I change only one.
    Posted by Yugen Hishiiro on April 11, 2019 at 10:04 pm
    I am trying to add an fx called s_blurmocurves. And I’m animating it with the time line. But after making key frames and changing the value of rotate, the value at other key frames also changes. And also it creates another key frame sometimes too. What am I doing wrong? This has been annoying me so much..
    Dimitrios Papadimitriou replied 7 years, 5 months ago 2 Members · 4 Replies
  • Yugen Hishiiro
    April 12, 2019 at 3:18 pm
    Anyone?
  • Dimitrios Papadimitriou
    April 12, 2019 at 4:34 pm
    it may be that you have to click the button to the right of the value. If you change rotate somewhere and it changes it through out the whole duration of the event it sounds like you haven’t clicked for that value to animate as for most of the plugins in vegas you have to individually select that you want to animate them. While some other only require you to press a single animate button. This is what it sounds like to me, I hesitated to answer because I’m really not sure. It may also be a bug, and I can’t test because I don’t have the plugin you are testing.
  • Yugen Hishiiro
    April 13, 2019 at 7:14 am
    The button to the right of the value is the clock icon which opens up the animate timeline. If i click that again, it’ll reset again. It’s probably a bug huh? My project is stuck because of this issue.. Sigh
    April 13, 2019 at 8:36 am
    I would try googling about that particular plugin to see if anyone else if having problems. Here is something I made about keyframes which may or may not be helpful to you.
    https://www.youtube.com/watch?v=8vRq7_wJgwY
