Forums Maxon Cinema 4D All Spline Point xyz handles automatically resetting to the middle of the scene
  • All Spline Point xyz handles automatically resetting to the middle of the scene
     Jim Scott updated 1 year, 1 month ago 2 Members · 3 Posts
  • Judd Stone
    May 2, 2020 at 8:32 pm
    Hello
    In just one project I probably did something wrong and now when I click on a spline bezier point, xyz handles are in the middle of the scene. also when I enable axis modification and move a handle position to the right place for a point, it happens again once I deselect and select the spline layer again.
    It also happens with new splines in this project but not in new projects.
    Thank you for your time.
    *I found out what happened, hope it helps someone else.
    to fix: Select a bezier point or an object in Move mode > Modeling Axis > Choose “Selected” under “Axis”.
  • Judd Stone
    May 2, 2020 at 10:04 pm
  • Jim Scott
    May 3, 2020 at 1:22 am
    Thanks for the follow-up.
Viewing 1 - 3 of 3 posts
Log in to reply.
