Activity › Forums › Adobe After Effects › All Paint Strokes(Clones) Parented to one Null
Posted by Bobby Dorrance on February 8, 2012 at 4:47 pmIs there a way to attach multiple strokes (clones) to a null with tracking data?
Vince Capistrano replied 14 years, 6 months ago 3 Members · 2 Replies -
Ben G unguren
February 8, 2012 at 7:31 pmI use expressions for this; it’s a simple pickwhip for where the clone is applied, but you also need to put in an expression for the clone is sampled (assuming you want it to move the sample point as well). For that, I make a point expression slider, then use that as an offset value, adding it to the clone point’s value.
I can provide an example in a bit if you’d like to see it. At the moment my computer is cranking out other stuff….
Ben Unguren
Motion Graphics & Editing
http://www.mostlydocumentary.comSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Vince Capistrano
February 9, 2012 at 6:58 amyou can use photoshop cs5 on that..
rockpaperscissorsph.com
