Activity Forums Apple Final Cut Pro Legacy All FCS2 Products crash?
  • All FCS2 Products crash?
    Posted by Elliot Pollaro on August 4, 2007 at 9:37 pm
    I have 2 g5 editing machines intel, just recently they both have been moving really slow and crashing left and right… could a software update caused this? I mean they just start closing for no reason… and it asks me if i would like to reopen… its really frustrating… any solutions?
    thanks
    Elliot Pollaro
    PollaroMedia
    Mark Maness replied 19 years, 1 month ago 6 Members · 12 Replies
  • 12 Replies
  • David Roth weiss
    August 4, 2007 at 9:51 pm
    Run Disk Utility — Repair Permissions on all drives.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY
    A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
  • John Foley
    August 4, 2007 at 10:29 pm
    Did you recently load Final Cut Studio 2 over Final Cut Studio(1)?
    If so, has it worked for you until now?
    I hear that there are problems loading one version on top of another??
    Please visit http://www.thefinalcutstore.com for all your Final Cut needs.
  • Elliot Pollaro
    August 4, 2007 at 11:48 pm
    yes i have upgraded.. also what would repair permissions do??
  • David Roth weiss
    August 5, 2007 at 12:30 am
    [jujuelliot] “what would repair permissions do??”
    Nothing other than fix what’s broken. Unix, the code underlying the MAC OS can get wacky from time to time, and repairing permissions from time to time straightens out that wackiness.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Elliot Pollaro
    August 5, 2007 at 1:59 am
    how long does that usually take. and will that mess up any of our saved projects or anything
  • Walter Biscardi
    August 5, 2007 at 2:03 am
    [jujuelliot] “I have 2 g5 editing machines intel”
    there is no such thing. G5’s are PowerPC machines. Mac Pro’s are Intel. Are these G5’s or Mac Pro’s?
    As David Weiss said, Repair Disk Permissions first and foremost on the Mac Harddrive. This takes approx. 2 minutes and checks for any errors on your startup disc. This will have zero effect on any current projects as far as damaging them in any way.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Elliot Pollaro
    August 5, 2007 at 2:19 am
    sorry mac pro.. not a G5
  • Elliot Pollaro
    August 5, 2007 at 2:25 am
    how do i repair it on a raid drive? i just repaired the macintosh hd drive but now my raid one wont let me?
  • Rafael Amador
    August 5, 2007 at 4:02 am
    If you want FC works fine, first make sure that your system is optimiced.
    There is a serie of maintenance routines that the Macs do by them self when they are not switch-off at night. If you switch-off your Mac every night you must run those routines by your self. Look for a little application call “Maintenance”. You can download it free in the Apple web-site.
    One of those tasks is “Repair permissions”. This is something that you must do to your System drive whenever you install something. With the Disk Utility.
    Appart of that there are two application, Diskwarrior and Techtools, to keep the directories of your HDs clean. I can not understand how is possible to work with MacOX without using one of those applications.
    Another think that helps your FC working properly is to have the the HDs that you use for editing (not the System driver) Un-journaled.
    I’m not the only one who thinks that the 75% of the crashes, hung and problems of FC come from a poor maintenance of the system.
    rafael
  • David Roth weiss
    August 5, 2007 at 6:16 am
    [jujuelliot] “how long does that usually take. and will that mess up any of our saved projects or anything”
    It takes about two minutes. And, do you think I would actually tell you to do something that would mess up your save projects? Come on, do you really?
    David Roth Weiss
    Director/Editor
    Los Angeles
