Activity Forums DaVinci Resolve All Clips are being graded at once?!
  • All Clips are being graded at once?!
    Posted by Rob Moragas on November 10, 2011 at 6:33 am
    Hi there,
    I am wondering if you can help. I have an XML exported from FCP. My original FCP edit was a single file in which I created split edits across scene changes. (Yes I know Davinci can do this too but I decided to do it in FCP)
    I Open the XML in Davinci and the XML opens and loads correctly showing me all the split edits that I previously created. The problem is the following. When I grade one of my split clips it’s grading everything in the timeline with the same grade. How come?
    Rob
    Rob Moragas replied 14 years, 10 months ago 3 Members · 6 Replies
  • Margus Voll
    November 10, 2011 at 7:47 am
    you have red box on every shot thumbnail yes ?
    if you have one media file then resolve sees it as one. just do batch copy or unlink and try to grade then.
    Margus
    https://iconstudios.eu
  • Ola Haldor voll
    November 10, 2011 at 8:38 am
    Margus has set you on the right course, but forgot to say; right click in the timeline where the thumbnails are, then you can select batch copy.
    This makes DaVinci treat every clip as individual clips.
  • Margus Voll
    November 10, 2011 at 8:40 am
    Yep thats it 🙂
    Sorry i pulled 24 h and forgot the last part.
    Margus
  • Rob Moragas
    November 10, 2011 at 9:38 am
    Thanks for the help all. I will try that tomorrow. When you do batch list or unlink does it copy media? Can I still re import the rendered files into fcp?
    Rob
  • Margus Voll
    November 10, 2011 at 10:54 am
    The media does not change. It is mostly “virtual” in resolve.
    Margus
  • Rob Moragas
    November 11, 2011 at 4:33 am
    Hi all and thanks for the help.
    When I do batch copy… what is it copying media? the timeline? I can’t see where the copy is if there is a copy or is it doing something else?
    Rob
