Activity Forums Adobe After Effects aligning text to mask/path head scratcher in CS4
  • aligning text to mask/path head scratcher in CS4
    Posted by Dan Nichols on June 10, 2009 at 7:17 pm
    i recently upgraded to CS4 from CS3, and i tried to place text along an eliptical path…simple enough, right. so i made the mask inside the text layer, went under path options in the text twirl down and selected the mask, unfortunately AE put the text in the MIDDLE of the elipse and squished the font along the x axis–it did not put the text resting ON the path, which it’s supposed to do, right? basically After Effects did not marry the text to the path…very strange…is there anyone that might be able to help me with this? greatly appreciated!
    David Bogie replied 17 years, 2 months ago 3 Members · 6 Replies
  • David Bogie
    June 10, 2009 at 7:37 pm
    Path Text is an obsolete effect these days. But it’s still there, just use the search field in the effects window.
    Also, you can find text on a path suggestions in the online manual.
    bogiesan
  • Brian Charles
    June 10, 2009 at 7:54 pm
    Turn on Reverse Path.
  • Dan Nichols
    June 10, 2009 at 8:00 pm
    i figured it out–it ended up being the baseline shift in the character palette of all things–isn’t it always something stupid like that…once again AE makes me look like a jacka## 🙂
    thanks, guys!
  • Dan Nichols
    June 10, 2009 at 8:02 pm
    for some reason the baseline shift was set to 87 in the character pallette window–not sure why, but i set that back to 0 and that was it! thanks for your help!
  • Dan Nichols
    June 10, 2009 at 8:08 pm
    did you even read my post?
    AE is doing a very strange thing WHEN i align text to a path. I was just looking for a possible explanation as to why?
  • David Bogie
    June 10, 2009 at 10:57 pm
    [Dan Nichols] “did you even read my post? “
    Apparently not. That happens around here. Probably will happen to you, too.
    Ever so glad you got accurate assistance, though.
    bogiesan
