Activity Forums Adobe After Effects aligning keyframes over multiple layers
  • aligning keyframes over multiple layers
    Posted by Kevin Reiner on July 11, 2008 at 2:23 pm
    I have a project that is about 60 layers with numerous keyframes on each layer.
    I was wondering if there is a shortcut key that will allow me to align the keyframes on multiple layers to the playhead location. I did a search, but couldn’t find much.
    Anyone know of this keystroke, or does it exist solely in my head?
    -Kevin
    System Setup (for a more detailed list, see my profile)
    HARDWARE
    Mac Pro 2 x 3 GHz Quad-Core Intel Xeon
    9GB Memory
    Two 16x SuperDrives
    Dual-channel 2Gb Fibre Channel PCI Express card
    Apple Cinema HD Display (23″ flat panel)
    ATI Radeon X1900 XT Graphics Card
    AJA Kona LHe SD/HD capture card
    Apple Xserve Raid 5.6TB
    SOFTWARE
    Mac OS X 10.4.11
    Final Cut Pro Studio 2
    After Effects CS3
    Photoshop CS3
    Illustrator CS3
    Boris Continuum 5
    Sapphire Plug Ins
    Roxio Toast
    Digital Anarchy Anarchist Suite
    ParticleIllusion 3.0
    Trapcode
    Zaxwerks
    Steven Perry replied 9 years, 7 months ago 4 Members · 4 Replies
  • Kevin Reiner
    July 11, 2008 at 4:47 pm
    Thanks Dave,
    Yeah, shift-dragging is what I am doing right now. It’s just that I’m doing it to allign keyframes that are spanning 60 layers. And I have about 30 instances of keyframes that need aligning. So I was hoping I could just drag and select a bunch of keyframes, hit the magic button and they all line up. I just can’t find the magic button. I even checked the bottom of my keyboard. Not there either.
    HARDWARE
    9GB Memory
    Two 16x SuperDrives
    SOFTWARE
    Mac OS X 10.4.11
    After Effects CS3
    Photoshop CS3
    Illustrator CS3
    Boris Continuum 5
    Sapphire Plug Ins
    Roxio Toast
    Trapcode
    Zaxwerks
  • Kevin Camp
    July 12, 2008 at 2:42 am
    the only way i can think of that might be able to accomplish what you are looking for is to create a script that would look at the first keyframe of selected layers and line them up to the current time position…
    it would be a pretty tricky script… it would need to search all parameters of each layer for keyframes and then reposition them relative to the first keyframe within a given parameter, and if some of the keyframes were within an effect, it would seem to get even more complex… yikes.
    it might be easier to make a script that would set the inpoint of selected layers to the first keyframe, then you could align the layers’ inpoints by hitting the ‘[‘ key, but i think it would probably be faster to do it by hand, unless you know somebody who is pretty good with java.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Chris West
    November 3, 2015 at 8:47 pm
  • Steven Perry
    January 7, 2017 at 1:08 am
    (old post I know)
    I like to program a macro into an extra mouse button (If you have a fancy mouse like I do) that does a sequential cut, and paste.
    This works great to select key frames layer by layer and hit the button each time to move the keyframe to playhead.
