Activity Forums Maxon Cinema 4D Aligning cubes
  • Aligning cubes
    Posted by Max Baxter on September 17, 2012 at 11:12 am
    I am trying to make a bunch of cubes (64 of them) to line up next to each other without any gaps so I can have a smooth clean image at the end but the problem is. Well. They arn’t lining up.
    It is an 8×8 face like a Minecraft face but without the additional depth just the front 64 blocks. I have tried using the “Drop It” plug-in which doesn’t work for what I need and I am not that experienced at Cinema 4D
    Max
    Tim Shetz replied 14 years ago 2 Members · 1 Reply
  • Tim Shetz
    September 17, 2012 at 7:38 pm
    If you have Mograph, you could use a cloner in linear mode.
    __________
    Tim Shetz
    c4dtraining.com
