Activity › Forums › Maxon Cinema 4D › Align to Spline problem
  • Align to Spline problem
    Posted by Thomas Taylor iii on September 10, 2011 at 5:41 am
    I have an object aligned to a circle spine using the align to spline tag. Problem. It key frames from 0% to 100% creating a 360 degree loop. I need it to continue on and continue to circle around but it only goes to 100% and 360 degrees. How can I get it to go 720 degrees or more on the same spline?
    Brian Jones replied 15 years ago 3 Members · 2 Replies
  • Randy Johnson
    September 10, 2011 at 2:30 pm
    Fastest way is to replace your circle with a Helix (height 0) and make it how many turns you want.
    /Randy
  • Brian Jones
    September 10, 2011 at 6:17 pm
    you can also use Repeat in the Track After setting in the AM when you are in the Timeline and have the have the Align to Spline’s Position track selected.
    2924_repeatafter.c4d.zip
