Activity Forums Maxon Cinema 4D align to path animation in cloner with shader to offset the time isnt working.
  • align to path animation in cloner with shader to offset the time isnt working.
    Posted by Chad Demoss on November 3, 2017 at 8:10 pm
    I have an animation of a sphere going around a spline using align to path animation from 0 position to 100 position and I put that in a null and put it in a cloner and it works fine. Now I want to vary the timing of the cloned spheres on the paths so I added a shader. If I try to change time offset in the shader the animation doesn’t animate anymore. if I try to add a gradient or noise to the shader and animate that the animation works but its not offsetting the timing.
    Ive used the shader on a cloner to offset time before but have never tried it on a align to path animation.
    Chad Demoss replied 8 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
