Activity Forums Adobe Photoshop align to center of canvas? distribute evenly?
  • align to center of canvas? distribute evenly?
    Posted by Zoe Woodworth on July 6, 2011 at 4:12 pm
    Is there any way to do either of these things in photoshop cs5?
    – center-align a layer to the canvas/page/artboard?
    – distribute several layers horizontally so that there is the same amount of space between the layers (this is different from distributing so that the center points of the layers are distributed evenly)
    Azat Salikhov replied 11 years, 3 months ago 4 Members · 3 Replies
  • Terry Mikkelsen
    July 6, 2011 at 4:19 pm
    As to the first question, simply select the layer in the layers palette, then with the black arrow tool selected press CMD+A to select all. Then goto Layer>Align Layers to Selection>Vertical Centers. Then repeat with Horizontal Centers.
    The second is more difficult and I haven’t found a good way to do it yet. I usually measure the distance between the objects, divide that number by the number of objects which then gives you the measurement needed between each object. Its a pain.
    Tech-T Productions
    http://www.technical-t.com
  • Richard Harrington
    July 11, 2011 at 12:32 am
    For #1 you can use make a solid layer that filsl the page and align to that.
    For Number 2. Make a shape (Such as a square) Then use snapping to drag and space the objects out.
    Layer l
    Snap Square to right edge.
    Drag Layer 2 to right edee of square
    SNAP
    Repeat
    Richard M. Harrington, PMP
    Author: From Still to Motion, Video Made on a Mac, Photoshop for Video, Understanding Adobe Photoshop, Final Cut Studio On the Spot and Motion Graphics with Adobe Creative Suite 5 Studio Techniques
  • Azat Salikhov
    May 21, 2015 at 10:18 pm
    To align to canvas, select your object, then go View->Snap to->Snap to page, then grab your object and align it manually using the green center lines to guide the correct placement.
