Activity Forums Blackmagic Design Alienware – ATEM Television Studio – Wirecast
  • Alienware – ATEM Television Studio – Wirecast
    Posted by Glenn Garnes on August 29, 2012 at 1:59 pm
    Does anyone have any experience with whether the ATEM Television Studio will work on an Alienware computer with Wirecast as the virtual switcher? Here is my configuration on the computer:
    OS including service pack and 32/64bit Windows 7 64 bit
    -Computer and CPU: Alienware Area 51
    OS Name Microsoft Windows 7 Ultimate
    Version 6.1.7601 Service Pack 1 Build 7601
    Other OS Description Not Available
    OS Manufacturer Microsoft Corporation
    System Name GGALIEN
    System Manufacturer Alienware
    System Model Area 51
    System Type x64-based PC
    Processor Intel(R) Core(TM) i7 CPU X 990 @ 3.47GHz, 3468 Mhz, 6 Core(s), 12 Logical Processor(s)
    BIOS Version/Date Alienware A10, 11/9/2010
    SMBIOS Version 2.5
    Windows Directory C:\Windows
    System Directory C:\Windows\system32
    Boot Device \Device\HarddiskVolume2
    Locale United States
    Hardware Abstraction Layer Version = “6.1.7601.17514”
    User Name GGALIEN\Glenn K. Garnes
    Time Zone Eastern Daylight Time
    Installed Physical Memory (RAM) 12.0 GB
    Total Physical Memory 12.0 GB
    Available Physical Memory 9.82 GB
    Total Virtual Memory 24.0 GB
    Available Virtual Memory 21.3 GB
    Page File Space 12.0 GB
    Page File C:\pagefile.sys
    -Graphics Card :
    Primary Adapter
    Graphics Card Manufacturer Built by AMD
    Graphics Chipset AMD Radeon HD 6990
    Device ID 671D
    Vendor 1002
    Subsystem ID 0B2A
    Subsystem Vendor ID 1002
    Graphics Bus Capability PCI Express 2.0
    Maximum Bus Setting PCI Express 2.0 x16
    BIOS Version 013.011.000.014
    BIOS Part Number 113-C2060100-104
    BIOS Date 2011/02/14
    Memory Size 2048 MB
    Memory Type GDDR5
    Core Clock in MHz 830 MHz
    Memory Clock in MHz 1250 MHz
    Total Memory Bandwidth in GByte/s 160.0 GByte/s
    Linked Adapter
    Device ID 671D
    Vendor 1002
    Subsystem ID 1B2A
    BIOS Part Number 113-C2060100-105
    Memory Size 2048 MB
    Memory Type GDDR5
    I would like to feed 3 or 4 Canon Vixia HG20’s into the ATEM Television Studio and use Wirecast to switch between them just as if they were on separate cards within my computer. Please advise.
    Justin Strauber replied 14 years ago 3 Members · 3 Replies
  • Alessandro Cofanelli
    August 29, 2012 at 3:29 pm
    you can’t do what you need.
    ATS is a standalone hardware switcher, not a computer card.
    You can control ATS from the computer using the provided software or using the sdk, but you can’t use wirecast to control atem.
    You can use wirecast to live stream or record output video coming from the ATM.
    Top Service Audiovisivi
    http://www.topserviceitalia.com
  • Glenn Garnes
    August 29, 2012 at 4:04 pm
    So, what would I use to do green screen/virtual sets if I can’t use Wirecast?
  • Justin Strauber
    August 29, 2012 at 10:19 pm
    You would either need an ATEM 1 M/E or 2 M/E and do the chroma key in that, or separate video capture cards for each camera. The TVS is a switcher, not a multi-port capture card.
