Activity Forums Maxon Cinema 4D Aliasing artifacts on extruded text
  • Aliasing artifacts on extruded text
    Posted by Cristi Dinu on April 3, 2015 at 9:35 pm
    Hello guys,
    I’m currently animating an extruded text in Cinema 4D and I’ve encountered a bit of a problem.
    I’ve used a shader from the Cinema 4D gallery as a material for the text and after I’ve rendered a Quicktime movie (Best Quality, 1920 x 1080) with Anti-Aliasing set to Best, filter set to Gauss (Animation), the face of the text look like no Anti-Aliasing was used at all.
    You can see a preview of the animation in the link below, the password is error:
    https://vimeo.com/124062801
    What can I do to eliminate the jittery display of the lines?
    Cristi Dinu replied 11 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
