Activity Forums Adobe After Effects Alexa ArriRaw – Can’t Import Footage as a Sequence in AE CS6
  • Alexa ArriRaw – Can’t Import Footage as a Sequence in AE CS6
    Posted by Steven Drypolcher on September 22, 2012 at 2:16 am
    I’m working with ARRIRAW footage which is recorded as a sequence of .ARI files. CS6 supports ARRIRAW, but it won’t allow me to import them as a sequence. Sooo… I imported them all as individual stills, selected all of them in my project, clicked ‘New Comp from Selection’, and specified the Still Duration as 1 frame. Now this ALMOST worked, but the fact that I can’t change it from Base 30 to Base 24 means that the each frame duration is too short for my 24fps composition.
    I’m kind of between a rock and a hard place on this, so any advice would be appreciated! I either need to be able to import my .ARI files as a sequence, or I need to be able to change the Still Duration to Base 24.
    Any advice would be much appreciated!
    Vishesh Arora replied 13 years, 11 months ago 2 Members · 1 Reply
  • Vishesh Arora
    September 22, 2012 at 7:06 pm
    Mr. Drypolcher
    In CS6 the option to change the Time code base is missing.
    If you have CS5, then
    Press ” Cntrl/Cmnd + Alt/Opt + Shift + K” or go to File>Project Settings
    There you can change the TIme COde Base.
    You can buy a trial version if you don’t have it with you.
    Vishesh Arora
    VFX and Motion Graphics Artist
    Blog:
    https://digieffects.wordpress.com
    Demo Reel(3D):
    https://www.youtube.com/watch?v=lHPgIJU_BR8
