Activity Forums Avid Media Composer ALEXA AMA plug-in and Avid Media Composer 8
  • ALEXA AMA plug-in and Avid Media Composer 8
    Posted by Vicente Perez on October 19, 2014 at 6:58 pm
    Is there anybody out there using the Alexa AMA plug-in on Avid Media Composer 8?
    I am working on a project that was shot on ArriRAW, with MXFs for offline editorial. I have installed the most recent Alexa AMA Plug-in (v1.5), but when I try to link the files, I get the dreaded “Segmentation Fault” in thread “MainThread”, at address 0x0 error.
    I can successfully link any other ProRes footage. Am I doing something wrong? Is there a chance that the Alexa AMA Plug-in might not yet be compatible with AMC8 (compatibility chart says AMC7)? I am able to open the MXFs using Premiere, so the files seem to be OK.
    Vicente Perez replied 11 years, 9 months ago 2 Members · 4 Replies
  • Michael Phillips
    October 19, 2014 at 7:54 pm
    Were the MXF proxies created by the camera or by another system like the Codex or a dailies program like Resolve, MTI, Colorfront, etc? If the files are DNxHD 36, then they were not done in camera as it can only record 115 and 175 flavors.
  • Vicente Perez
    October 19, 2014 at 8:06 pm
    Thanks for your prompt response, Michael. I have been told that they are proxies created by the camera. I am going to check with the DIT to confirm the exact flavor.
  • Michael Phillips
    October 19, 2014 at 8:12 pm
    What’s the DNxHD format being delivered data rate wise?
    Michael
  • Vicente Perez
    November 20, 2014 at 8:20 pm
    Thank you for your help. You were completely right. The AE was running the footage through DaVinci without telling me. Knowing that, everything works as it should.
