Activity › Forums › Apple Final Cut Pro Legacy › Alexa 23.98 footage – deliver 29.97 :30 commercial for TV – FCP 7
  • Alexa 23.98 footage – deliver 29.97 :30 commercial for TV – FCP 7
    Posted by Jesse Mendelson on May 21, 2013 at 6:30 pm
    Hi all,
    just wanted to take a quick poll. I’ll have 2-3 hours of Alexa footage shot at 23.98 that I will be editing into a :30 commercial for broadcast TV, thus will need to be 29.97.
    Anyone think I should conform all dailies to 29.97 in cinema tools before editing?
    FYI – I don’t have an AJA card.
    Thanks in advance,
    Jesse.
    Jesse Mendelson replied 13 years, 4 months ago 2 Members · 2 Replies
  • Shane Ross
    May 21, 2013 at 6:54 pm
    [jesse mendelson] “Anyone think I should conform all dailies to 29.97 in cinema tools before editing?”
    No. Edit 23.98.
    How does this need to be delivered? Digital file? Tape? Compressor does a great job of converting 23.98 to interlaced 29.97…very fast too.
    23.98 to 29.97 via Compressor:
    1. Drop clips you want to convert into Compressor
    2. In Compressor, select your video then right click and choose NEW TARGET WITH SETTING > APPLE > FORMATS > QUICKTIME > APPLE PRORES 422 (HQ). Or pick whatever codec you like to work with.
    3. Click on that newly created compression setting to open it in the Inspector window. Click the Encoder tab. Click the Video: (Settings…) button. Make the frame rate 29.97. Check the interlaced box. Set it’s drop down menu to Bottom field first. Click OK.
    4. Click the Frame Controls tab. Set Frame Controls to On. Set Output Fields to Bottom first. Leave Deinterlace on Fast. Leave Adaptive Details checked. Leave Rate Conversion set to Fast. Leave the Set Duration to: on 100% and make sure it’s radio button is selected and NOT the “so source frames play at 29.97 fps” button.
    5. Make changes to the Filters or Geometry sections as needed. Those settings listed above are the ones critical to getting the proper 3:2 pulldown added.
    6. Submit the compression, then bring the resulting video back into Final Cut Pro. Place it in a 29.97 timeline and make sure you watch it on an NTSC monitor to verify that it looks good. If you step through it frame-by-frame you should see the familiar pattern of 2 split/interlaced frames followed by 3 whole frames. This is a very important step. I tried many solutions that looked OK playing back on the computer monitor, but looked terrible on the NTSC monitor.
    Shane
    Little Frog Post
  • Jesse Mendelson
    May 21, 2013 at 6:58 pm
    Thanks Shane! Delivering digital file only. Done the conversions in Compressor before – although probably not with your expert settings, but will going forward.
    appreciate it!!!
    best,
    jesse.
